Kenpcfl
Using the radio system while not driving (i.e., parked and just listening to music) continues to run the hour meter, because the key has to be in the ON position. This is something we do frequently and would not be a true representation of vehicle total time usage. Right now, out of the 12 hrs shown on the meter, likely 4 hrs are for just using the radio and not under way.
Ideally, the NAV should have an "accessory" position that is not tied to the hour meter. I will add this to my full review under "wish list".
As a work-around, I am planning to move the 12v switched wire from the key circuit, to another always on circuit. Then, I will use the radio power knob to turn on and off.
Note: I do not have the backup camera, so that's not an issue. I might as well disconnect that reverse camera trigger wire while I'm at it. It's an irritating screen message of "no video feed" everytime you go into reverse.
