Installed back up camera and says no video source..
Mattyboy011
NY
I have the Nav limited and recently installed the back up camera from Kawasaki. It was super easy and involved one connection. However when you put the cart in reverse it says no video source. I even tried another camera and got the same message? Does anybody have an idea about what the issue could be? I reset the display unit, checked fuses and connections and all is good. Thanks for any ideas!
Can you access it manually from the home screen camera icon? When in that screen you may have to toggle from front to rear view (upper right corner).
I have tried that.. it always seems to default to front camera and then you toggle to rear view and still nothing. It makes no sense and is prob a simple solution. I was wondering if the Hiphonics screen needed an update ?
Mine defaults to front cam position each time I try the manual method also, but it does turn on cam when I toggle it to rear cam. Since you cannot turn it on it manualy, that means it's not related to the reverse trigger wire. Try unplugging the camera connector and see if there is 12v power on the receptical when powered on manually (using a multimeter).
I will have to try that..
