- Joined
- Feb 18, 2025
- Messages
- 25
- Reaction score
- 4
Kawasaki today released the information on the Kawasaki Nav 4e. I'll be uploading more assets throughout the day but here is the full press release below.
NAV® 4e
Kawasaki's first-ever electric four-wheeled vehicle is more than just a way to cruise the neighborhood or run errands, it is a new way of life. You will no longer be going to your neighbors, or the local pickleball court, you will NAV to your desired location. With a prominent Kawasaki emblem, a lifted appearance and electric vehicle (EV) front-end styling the all-new NAV® 4e is set to turn heads.
Once you slide inside the NAV 4e Personal Transportation Vehicle (PTV) you will be amazed by the well-appointed interior with amply padded seats and plenty of leg and shoulder room to conveniently NAV the neighborhood in comfort and style.
For 2025, the NAV® 4e can be found in three different model configurations with the NAV 4e, the NAV® 4e LE and the flagship NAV® 4e Limited. The NAV 4e LE model offers an upgrade to lithium-ion batteries while the NAV 4e Limited model includes lithium-ion batteries, 7” full-color TFT instrumentation, audio system, brush-guard style front bumper, a flip-down windshield, premium seats and steering wheel along with floor lighting and more.
KEY FEATURES
● Smooth, simple induction electric motor rated at 4 kW output
● Two battery Types: Lithium-ion (LE, Limited) and lead acid
● Premium lifted style
● 14” wheels with 23” off-road style tires
● Unique Kawasaki front-end styling
● Roomy interior layout
● Elegant and comfortable seats
● Passenger-centered convenience
● Comfortable chassis design
● First in category* fold-flat rear seat
● Spacious front and rear storage
ELECTRIC MOTOR
The NAV 4e features a rear-mounted single-motor unit that drives the rear wheels. The ACmotor produces a maximum of 10.7 kW of power and its output is rated at 4.0 kW, which offers mild, smooth acceleration along with plenty of torque at any rpm. The smooth power makes it easy to reach a maximum speed of 19 mph. The power is transferred from the motor to the rear wheel via fixed gear transmission with the motor and transmission integrated into the rear axle. There are three drive modes, forward, neutral, and reverse, and it also features a vehicle-specific key to help deter theft. TheNAV 4e also features a one-key system, meaning the ignition key also locks/unlocks the glove box.
TWO BATTERY TYPES
The NAV® 4e offers two types of batteries. On NAV® 4e LE and Limited models, two 3.2 kWh lithium-ion batteries offer a range of up to 40 miles and are ideal for carrying passengers on long trips. The standard NAV® 4e model, with a set of six lead-acid batteries, has a range of up to 17.5 miles. Both can be easily charged via a charging socket on the dash panel under the steering wheel. Simply plug the charger into a standard household electrical outlet, and you're good to go. Charging time on the NAV® 4e can take up to 10 hours (0-100%) and 11 hours on the NAV 4e LE and Limited models. Charging times may vary. Thanks to the regenerative system, every time you release the accelerator pedal, the deceleration energy is recycled back into the battery— extending your cruising range, and as the batteries approach full charge, the regenerative function gradually tapers off.
CHASSIS
Inspired by Kawasaki’s expertise with side x side chassis designs, the NAV 4e features a steel frame that is both tough and durable, designed to provide a comfortable ride. Drawing from Kawasaki’s ladder-type construction with square steel tubes, the frame ensures stability and contributes to excellent ride comfort. The long wheelbase design offers ample legroom for rear passengers while maintaining a minimum turning radius of approximately 12.8 ft., making it easy to maneuver.
An elevated seating position provides both driver and passenger with an excellent vantage point, enhancing visibility, comfort, and peace of mind. With 7.3 inches of ground clearance, the NAV4e combines stylish design with the ability to handle uneven pathways. Accessories like running boards further facilitate entry and exit, even with the lifted floor.
All NAV 4e models come standard with a roof, while the NAV 4e Limited model is equipped with a flip-down hard-coated polycarbonate windshield featuring screen printing. This windshield can be fully extended or folded in half, offering protection from the elements and a relaxing ride. The roof’s innovative design includes a water drainage system that channels rainwater down the A-pillars and out through the wheel wells.
The NAV 4e also boasts practicality, with a 2-inch hitch receiver at the rear that accommodates various accessories, including a rear cargo rack, and provides a towing capacity of up to 500 lbs. The batteries are strategically located under the front seats, positioned horizontally across the chassis width to enhance stability. This design allows rear passengers to enjoy additional legroom and comfort.
SUSPENSION AND BRAKES
To provide a more comfortable ride, the NAV 4e features independent MacPherson struts front suspension, which can also be found on some of Kawasaki’s MULE(™) side x side models, and a conventional swing axle comprised of a shock unit with leaf springs for the rear suspension also helps with ride comfort and contributes to reliability and durability. The 160mm rear drum brakes offer plenty of stopping power to suit the NAV 4e’s top speed. The parking brake functions as a typical PTV parking brake, activated by pressing the top portion of the two-piece brake pedal.
OFF-ROAD WHEELS AND TIRES
14-inch wheels combined with 23-inch off-road style tires are mounted on the NAV 4e to provide ample traction in a variety of environments. The tires feature a solid-looking tread pattern that accentuates the lifted style of the NAV. On the NAV 4e Limited, the wheels feature a machined finish that is inspired by Kawasaki’s premium side x sides and are complemented by chrome-plated wheel center caps to further contribute to the high-grade look of the vehicle.
FOLD FLAT SEAT
A first in the four-forward category, the fold-flat seat on the NAV 4e allows the rear seat to be folded to create a flat cargo area in the rear. This enables larger items to be carried on a flat deck, increasing the versatility and capability of the NAV 4e. With the rear seat folded flat and the damper-equipped backrest flipped up, the flat cargo area created has a 150 lb. capacity and is the largest in its category at 31 x 40-inches. The cargo area features slots for KQR accessory mounts, with quick-release capability, allowing for the use of a variety of genuine accessories. When not in use, KQR mounts can be conveniently kept in slots built into the armrests of the seats. The cargo surface includes anti-slip grooves designed to help keep multiple five-gallon buckets in place and Kawasaki GenuineAccessory cargo barriers for the cargo area are available to keep larger items in place, further expanding the cargo capabilities of the NAV 4e.
CONVENIENT STORAGE
Under the front hood, the NAV 4e provides a six-gallon storage compartment capable of holding up to 10 lbs., offering protection from the elements. Additional storage compartments in the dashboard enhance convenience, keeping items within easy reach. On the left side, a .5-gallon storage compartment is ideal for quickly accessing items, while the center compartment includes a closeable lid with one gallon of storage capacity. A lockable glove box on the right offers 1.6 gallons of space and features a USB outlet for added functionality. This glove box can be locked or unlocked using the ignition key, enhancing security and peace of mind.
In the NAV 4e Limited model, a storage net attached to the back of the front seat provides rear passengers with a convenient spot to carry miscellaneous items. Furthermore, a small cut-out in the wall under the rear seat creates space for smaller items, and an optional storage net accessory can secure items behind the feet of rear passengers, enhancing storage options in the rear. Finally, a rear compartment offers nearly three gallons of storage, accommodating up to 10 lbs.
PREMIUM EXTERIOR
The NAV 4e was designed with a lifted style that embodies a "premium, sporty and active" lifestyle. Inspired by Kawasaki’s side x sides, the NAV 4e has a distinctive and unique appearance. Its EV-inspired grille features a clear honeycomb pattern with a painted back, giving it an advanced texture that associates the NAV 4e with modern electric vehicles and elevates its pride of ownership. Adding to its premium design, a 3D Kawasaki emblem prominently displays the trusted quality and brand recognition of Kawasaki.
On the NAV 4e Limited, a brush-guard-style front bumper enhances the rugged aesthetic. Borrowing design cues from Kawasaki’s premium side x sides, the hexagon-shaped steel bumper features attractive plastic covers, creating a high-quality, unique-to-class front end. The aggressive LED headlights further complement the sporty, active style of the NAV 4e. These headlights, consisting of six chambers (three high beam, two low beam, and one turn signal), offer excellent brightness and functionality. A position light is integrated into one of the high-beam chambers. The turn signals are seamlessly integrated into the headlights on all models, maintaining a premium, uncluttered look.
The front fenders, constructed from black plastic, add a functional and robust appearance while sitting high above the front wheels to emphasize the lifted style. At the rear, LED taillights double as brake lights and include integrated turn signals for additional functionality.
Color options and design concepts further define the aesthetic of the NAV 4e. The standard and LE models embrace a sporty theme, featuring Vibrant Blue for the standard model and Super Black for the LE model, and are stylish for everyday use. The NAV 4e Limited model conveys elegance, with its Metallic Deep Red exterior offering a luxurious look that complements the black and brown seats and gray roof of its interior.
PREMIUM INTERIOR
The thoughtfully designed interior of the NAV 4e combines functionality and comfort to ensure an enjoyable experience for all passengers. Featuring stylish, cushioned seats, numerous charging points, and ample storage compartments, including a lockable glove box, the NAV 4e ensures passengers have convenient places to store their items, can charge their devices, and stay entertained. The plush bench seats offer sofa-like comfort whether driving or parked.
In addition, the NAV 4e Limited offers a color-matched dashboard center console, a premium wireless-connected four-speaker audio system, and elegant two-tone leatherette seats featuring visible needlework and embroidered NAV branding for a luxurious touch.
The D-shaped steering wheel on the NAV 4e combines style and functionality, providing ample leg clearance and a modern look. The steering column is fully covered for a premium feel, while the NAV 4e Limited features a Kawasaki emblem and decorative covers. The steering column cover also includes intuitive controls such as a horn, turn signals, drive mode switches (Forward/Neutral/Reverse), and a hazard light button. Located behind the steering wheel is a full-color TFT instrument panel with a 1.5-inch display, providing key information such as gear position, hour meter, battery charge level, and turn signal indicators. To enhance the premium experience, the system features animation with the Kawasaki logo upon powering the NAV 4e on and off.
The footwell design maximizes open space, offering exceptional comfort for front-seat passengers. A key switch on the steering column allows for intuitive vehicle operation, while an automotive-style dashboard adds to the premium feel of the NAV 4e. The center console varies across models, offering a storage pocket in the Standard and LE models. The NAV 4e Limited offers a 7-inch full-color TFT display and features an exterior paint-matched console for a cohesive and modern look.
The NAV 4e provides thoughtful details for passengers, such as four front cup holders accommodating 30oz. tumblers or 500ml. bottles, and two rear cup holders attached to the front seats. A multi-mount bar above the dashboard with a standard ⅞” diameter offers additional mounting options, while a rearview mirror on the roof and optional side mirrors enhance the range of vision. Grab bars are conveniently integrated into the rugged roof support structure , and large armrests add to passenger comfort. The front armrests attach directly to the frame for a solid feel, and the rear armrests include slots for accessory mounts.
Convenience is further enhanced with multiple USB outlets. The NAV 4e and the NAV 4e LE models include four Type-A USB outlets, two in the front and two in the rear, while the NAV 4e Limited model adds two additional outlets (one Type-A and one Type-C) in the center storage compartment. Floor lighting on the NAV 4e Limited adds a premium touch and practical visibility, while rubber mats provide enhanced grip throughout the interior.
Space and comfort are prioritized for rear passengers, with thoughtful battery placement that allows for more knee and toe room. The generous space between the front seat and rear passengers’ knees contributes to a spacious, comfortable feel, while the elevated rear seats provide a clear view and ample legroom, ensuring all passengers enjoy the ride.
AUDIO SYSTEM
The NAV 4e Limited features a large 7-inch high-grade full-color TFT LCD screen integrated into its automotive-style dashboard, adding to the vehicle's high-quality and modern feel. This screen is compatible with the automotive capabilities of both major mobile operating systems, providing passengers with a variety of options for entertainment, navigation, and connectivity. A built-in microphone allows for seamless telephone conversations when wirelessly connected to a smartphone, ensuring convenience and functionality during rides.
For a superior audio experience, the NAV 4e Limited is equipped with four 6.5-inch roof-mounted speakers that deliver ample sound for in-vehicle entertainment, making every journey enjoyable. Additionally, a subwoofer, available as a Kawasaki Genuine Accessory, can be installed in the under-hood storage compartment to enhance the audio system further with deep, rich bass.
ACCESSORIES
The NAV 4e features a full complement of accessories to make exploring your neighborhood even more fun. A flip-down polycarbonate windshield that can be fully extended or folded in half to suit various conditions is available. The windshield is quantum hard coated for scratch and UV resistance, with screen printing that adds a premium aesthetic. For additional weather protection, a black premium soft enclosure made from durable 600D polyester fabric, can be added to the NAV 4e. This enclosure includes zippered front and rear doors, a zippered rear panel, and large clear vinyl windows. All panels can be rolled up and stored when not in use, with screen-printed logos further emphasizing its premium image.
A rugged brush-guard-style front bumper that reinforces an off-road look can be added, along with running boards to complement the lifted style by reducing step height for easier entry and exit. The running boards are finished with a durable textured powder coat. For lighting needs, a set of 3 x 3-inch LED pod lights with flood beam pattern reflectors can be mounted on the frame using the LED windshield pod light mount kit. This pod light features cast aluminum housing with a black powder coating, and the mount kit allows it to be positioned on the lower A-pillars for adjustable direction. Also available is an LED dome light that conveniently illuminates the interior of the vehicle while organizing your belongings. Since it’s battery-operated, there is a quick, wireless installation.
A side mirror set is available, aiding the driver in monitoring the sides and rear of the vehicle while adding a touch of style. Overhead storage includes two large, zipped pockets, two sunglasses pockets, a mesh pocket, and a bungee system for securing items. Additionally, a storage net provides space for securing items behind the rear passengers' feet, and a molded black plastic rear locking storage box adds further sealed storage options.
For cargo management, supplemental cargo barriers can help retain items in the rear cargo area while providing integrated tie-down points. These barriers can be installed or stored using accessory KQR Mounts, which also support the multi-function rack. This rack can hold up to four beach chairs or two golf bags and features foldable arms for added versatility. The rear cargo rack, with a 120 lb. load capacity, can be attached to the hitch receiver and features raised rails, tie-down points, and a textured powder coat finish for durability. Lastly, KQR mounts enable quick installation of various accessories and can be conveniently stored when not in use. Other storage-related accessories include a trailer hitch, hitch pin, 2-inch ball, and reducer bushing, ensuring the NAV 4e is equipped for diverse needs.
To top it off, all Kawasaki NAV 4e PTV vehicles are confidently backed by a 2-Year Limited Warranty, with the lead-acid batteries holding a 24-month limited warranty and the lithium-ion batteries holding a 72-month limited warranty.
2025 Model Variations
Kawasaki NAV 4e
Colors: Vibrant Blue
MSRP: $12,999
Availability: March 2025
Kawasaki NAV 4e LE
Colors: Super Black
MSRP: $15,999
Kawasaki NAV 4e LIMITED
Colors: Metallic Deep Red
MSRP: $19,999
